Trace tool problems in ArcHydro 2.1/ArcGIS 10.1
1195
10-26-2012 02:03 AM
marzolff
Has anyone had problems with using the "trace feature by NextDownID" in the latest ArcHydro version (2.1) under ArcGIS 10.1? I have created an ArcHydro Network and try to select catchment polygons by tracing upstream from a HydroJunction, as well as select drainage lines by tracing upstream from a downstream segment. In all cases, only the HydroJunction or drainage line segment I have clicked with the trace tool gets selected, nothing upstreams.
I have used this tool in the same way ever so often under ArcGIS 10 with earlier ArcHydro versions and never had problems. Couold this be a new bug?
Best regards,
Irene
ChristineDartiguenave
There was a bug (indexing changed from 1 to 0). This is fixed in versions 10.1.0.78 (and later) available on the ftp site.
Christine Dartiguenave
Esri Water Resources Team
