I've found this to be a great tool and better than the standard toolbox downstream trace. Today, I'm getting errors I've never seen before from this tool. Any advice on what can be done to fix these server messages would be great. Any hint appreciated, thanks.
what are your inputs? since nothing is returned, is there an error there? check those in Results
Hello, I'm running the tool from the right hand tray in arcmap under ready to use services, and the input is a FC of points in arcmap, which is how I've run the tool before. There is no error in the input in geoprocessing results, just in the server messages, unfortunately.
I'm referring to this hosted geoprocessing service - Trace Downstream—ArcGIS REST API: Elevation Analysis services | ArcGIS for Developers
used in ArcMap. I have normally accessed this via citrix arcmap, from the arccatalog drawer, ready to use services, and was getting the error messages in the first screenshot. We had some network issues on our end yesterday, so maybe that was it, but the same data with and without the optional parameters all worked correctly today. -?-
strange? no clue then...
It'd be easier if you just capture the screen and post to us so we know what you are talking about.
