Performing Upslope Analysis for a large number of points
377
05-13-2024 06:31 AM
Labels (2)
AlecWalker1
I am attempting to perform a landslide analysis of a large area of the UK (the north york moors) and am struggling to collect a parameter for each point I am considering (a 10mx10m resolution).
I require the proportion of the upslope area with slope angle >23 degrees for each point. I have completed the required slope analysis with a raster output but am struggling with finding how to complete the next stage of analysis interms of upslope area. Any recommendations of a procedure I could use to undertake this?
Many thanks for any suggestions.
BobBooth1
You could use the Watershed tool to identify the upslope cells for each point.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/watershed.htm
Use it in loop and make a separate output for each point (use Python or ModelBuilder to automate this, naming each output using a unique value associated with the given study point).
Use Con to determine, for all cells, which ones are greater than 23 degrees slope and code them as 1.
https://pro.arcgis.com/en/pro-app/latest/tool-reference/spatial-analyst/con-.htm
Then use the output upslope watershed for each point to summarize the number of cells in that watershed that have have a value of 1.
Could probably use Zonal Statistics for that:
https://pro.arcgis.com/en/pro-app/latest/help/analysis/raster-functions/zonal-statistics-global-func...
https://gis.stackexchange.com/questions/142412/counting-number-of-raster-cells-satisfying-a-criteria...
AlecWalker1
Amazing, thank you for the advice I'll see what I can do!
AlecWalker1
Do you think this would be viable for a 32 million point dataset?
BobBooth1
Well, as I said, you will need to do some automation.
It may also be useful to break up the input points into chunks in different feature classes to process.
