New password for Arc Hydro ftp Site - September, 5 2014
14175
17
09-05-2014 07:59 AM
ChristineDartiguenave
Note the new password for the ftp site as of 09/05/2014:
User login:  ADSRiverHydraulics
Password changed to:  ADSRiver.2014b
To access, select a FTP client:
1. Web Client
Site link: https://mft.esri.com
(Video tutorials available on the main page, prior to log in)
2. Third party SFTP client
** Download a preconfigured client
https://mft.esri.com/EFTClient/Account/mft.zip **
3. FTP address to configure a third party SFTP client of your choice:
Site address: mft.esri.com
Port: 22
Christine Dartiguenave
Esri Water Resources Team
V_StuartFoote
MVP Frequent Contributor
Christine Dartiguenave‌, *,
Thanks for the heads-up!  Verified the new credentials are working.
Stuart
josephkayode_Aro
hi, Been trying to gget the new archydro as the previous version i installed always hangs when i get to catchment polygon delineation. However, i have a problem with the password as i`ve tried all clients both web, filezilla and mft and i seem to be getting error with the new pass ADSRiver.2014b. please id appreciate your prompt reply. bidex99@gmail.com
V_StuartFoote
joseph kayode Aro
Just opened the site from a sftp session in FileZilla using credentials above.  All seems in order.
Give it another go, but perhaps try a different application (I've rarely had issues using FileZilla).
Stuart
RuthOla
Hi Christine,
When will HEC GeoRAS that is compatible with ArcGIS 10.2.2 be available?
Regards
Ruth
EpicEngineering
I just tried the credentials above and it kept giving me an error. I need to download at least Arc Hydro Tools Version 10.2.0.75 for HecGeoHMS 10.2.
Thank you!
Kim Coburn
kcoburn@epiceng.net
V_StuartFoote
Confirming inability to connect to mft.esri.com...  pings OK, but might need a bump to restart things.
Stuart
EpicEngineering
Yay it is working! I have no idea what you did but it worked. Thank you!
Kim Coburn
kcoburn@epiceng.net
EpicEngineering
Hello Stuart,
I was able to download the latest version of ArcHydro through this ftp site fro both the regular and x64 version which was version 10.2.0.40. Do you know where I could find Arc Hydro Tools Version 10.2.0.75? HecGeoHMS 10.2. requires that version.
HEC-GeoHMS Downloads
Thank you,
Kim Coburn
kcoburn@epiceng.net
EpicEngineering
I apologize, I download an old version. I have been since able to download the version 10.2.0.94 which works with the latest HecGeoHMS.
Thank you for all of your help!
Kim Coburn
kcoburn@epiceng.net
