Mosaic maps of Canada
3905
09-11-2012 09:23 AM
SylviaSusanto
I am doing research for my master degree and I need the following maps:
1. Satellite mosaic of Canada in winter
2. Satellite mosaic of Canada in summer
3. Map of Canadian rivers
Could anyone help me to get the above maps or direct me to the specialist or industrial who created the maps.
Any help will be much appreciated.
AnthonyGiles
Honored Contributor
susantos,
It looks like you are going to have a long road ahead. An mxd is essentially a project that you then add data to, ArcGIS supports many file formats of data, see:
http://webhelp.esri.com/arcgisdesktop/9.3/index.cfm?TopicName=Data_formats_supported_in_ArcGIS
Tiff files are an ideal raster format for ArcGIS.
Regards
Anthony
P.S. Please don't forget to mark posts as answered as this helps others using the forums. This can be done by marking the correct answer to your question as follows:
[ATTACH=CONFIG]17614[/ATTACH]
AnthonyGiles
Honored Contributor
Susantos,
Try this ftp site:
http://geogratis.cgdi.gc.ca/download/
Regards
Anthony
SylviaSusanto
Thank you Anthony,
I went to the website and found mosaic Canada but in TIFF image format. I need maps in the format that I could edit using ArcGIS because I need to create new maps based on the three maps that I need.
I am just learning how to use ArcGIS. Could we edit TIFF image using ArcGIS. So far I thought that I need in .mxd format.
Thanks
Sylvia
Susantos,
Try this ftp site:
Regards
Anthony
AnthonyGiles
Honored Contributor
susantos,
Regards
Anthony
