Importing RAS data failed
1992
03-27-2020 12:16 PM
WeiLuo
I downloaded and installed the latest HEC-GeoRAS (10.7) from yellow.esri.com - /archydro/HecGeoRAS/10.7/. I prepared the geometry data in HEC_GeoRAS, exported the data to HEC-RAS (5.07),ran the model; everything worked fine to this step, but when I tried to bring the result back to ArcGIS for visualization, I got "Importing RAS data failed!" and "RAS configuration is not supported!."  I did some search and tried to delete the decimal digits in spatial reference in the .xml file as one post suggested, but it still did not work, got same error messages. Any ideas or work around? Should I go back to an earlier version? Many thanks for your help!
Wei
Tags (1)
WeiLuo
Okay, I figured out after reading some other posts. So you need to convert the .SDF file to .XML file. I was able to import successfully. However, I have another problem in computing the floodplain delineation using rasters.
