Hydrotools: Blanking irrelevant data out
1955
05-08-2013 01:48 AM
PhilippKlippert
Hello
I have a Question. Right now I am using DGM Data and the Hydro Tool is working fine.
The Situation is:
I used the flow-direction tool. The result is absolutely fine. But now i need to relate the results to (for example) a lake. Can i somehow filter out only the relevant flow-directions that go towards the lake? All the other directions are not relevant, so i want to blank them out.
Thanks in advance
DuncanHornby
MVP Notable Contributor
Upload an image of what you are trying to achieve.
MarkBoucher
Honored Contributor
If you have the fdr grid, you should be able to deliniate all areas that flow to the lake by creating a watershed from the lake outlet. This would give you a polygon. Then you can use a polygon of the lake to mask out the lake and result in the areas that flow to it.
