I have received a couple of e-mails indicating my prior post is not very clear and hard to follow. Below is my best try:
1. Use Batch Point Generation Tool to create a point layer containing your reservoir points/locations. Make
sure those points are on the DEM streams.
2. Make sure your point layer has following fields: Descript, BatchDone, and SnapOn. If there are not in your
point file, add them and populate them.
3. Run Batch Subbasin Delineation Tool to further delineate subbasins for those reservoirs; Those reservoir
points will be added into your ProjectPoint layer.
4. Make sure the Type and HyElmType fields in the ProjectPoint layer are populated with "5" and "Reservoir"
respectively.
Please refer to Chapter 8 of the User Manual, Batch Subbasin Delineation.
