HEC-GeoRAS XS Cutlines Filtering Points
3434
03-05-2013 07:20 AM
DarylSantos
Is there a way to filter the number of points on XSCutLines using HEC-GeoRAS on ArcMap before the file is exported to HEC-RAS?
ChristineDartiguenave
No you cannot do this in HEC-GeoRAS. The filtering needs to be done in HEC-RAS.
Christine Dartiguenave
Esri Water Resources Team
FYI - There is a new tool in Arc Hydro, Thin Cross-Section, available in the Arc Hydro Tools toolbox>H&H Modeling>Utility toolset that allows filtering the vertices in cross sections using either a fixed number of vertices or a fraction of the original number of vertices.
