Fill Sinks Error
3933
02-18-2013 02:12 PM
KenSheehan
In running hydro 10.1 beta (and the GeoHMS 10.1 from the Army Corps version which I installed and removed trying to fix this problem) I get the attached error message every time I try to fill sinks. This happens either from ArcToolbox or the toolbar. I have set my extent to an appropriate size to make sure that's not a problem. Cleared my temp file as was also suggested in hydro help thread, but still a no go. Any suggestions? Additional info needed? Thanks...
MarkBoucher
Honored Contributor
Ken,
The error messages are usually not helpful to me. They seem to provide information only the ESRI developers can understand.
After you get the error, try refreshing your ArcCatalog folder to see if it is created anyway. It could be there. If it is, you will likely need to set the Spatial Reference and it is likely useful.
Are your project directories on a network or your local PC? I recently found that moving the project onto my local PC eliminated most of the crashes and errors. I make sure the under File>Map Document Properties I click the box for "Store relative pathnames..."  This lets me move the project back to the network server without disconnecting the layers.
Mark
