Error in DEM Reconditioning in Arc hydro 10
24807
40
10-04-2012 11:53 AM
by Anonymous User
Not applicable
Original User: souris_boo
Hi!
I just installed Arc Hydro for ArcGis 10 and i receive this error in processing DEM Reconditioning
"Error HRESULT E_FAIL has been returned from a call to a COM component"
Help please
Natalie
by Anonymous User
Not applicable
Original User: synaps
Everything done right, but result is the same!
I think I have found a clue 😉
See the first attachment and the folder where ArcGIS takes an ObjectID field. Why so? My hydroconfig .gdb and temp folder were in the D:\ dirrectory
MattNash
Hi, has anybody made any progress on these errors?  I get the " HRESULT E_FAIL " and "error 010024: Error during conversion" and am completely unable to use ArcHydro since installing the most current version after getting upgraded to ArcGiS 10.1.  I'm experienced with the toolset and have followed all advice given here for setting up.  Any advice would be most appreciated.
by Anonymous User
Not applicable
Original User: mattnash
I un- and re-installed Arc Hydro Tools and tried to run it again.  When trying to "Set Target Locations", which seems simple enough, I get a "tool not valid" error.  None of the tools function, various errors are returned from all of them. I'm not delivering as promised, and I'm losing my cred, man.
by Anonymous User
Not applicable
I`ve just installed BETA 10.1 http://blogs.esri.com/esri/arcgis/2012/11/26/are-you-using-arc-hydro-tools-for-10-1-beta/ and my comp freezes and returns me with the message "tool not valid" for all of them.
V_StuartFoote
MVP Frequent Contributor
Dmitrii,
Are you by chance on ArcGIS Desktop 10.0? The ArcHydro Beta (build 10.1.0.52) is for ArcGIS for Desktop 10.1
You'd need an ArcHydro for 10.0 (last build was 2.1.0.116) if you are on Desktop 10.0
Stuart
by Anonymous User
Not applicable
Yes, I use 10.1 SP1 and this error appears when I use the new Beta version.
I posted here due to the fact my previous messages describing some errors that I got are still in this topic.
FranklinEbner
I was getting this error message "Error HRESULT E_FAIL has been returned from a call to a COM component" and finally exported my data into a gdb feature class from a shapefile.  Now it works, thank you to this thread!
BritneyVazquez
I am similarly having issues with the DEM reconditioning tool. I have tried all of the suggested solutions, including those found in the Arc Hydro Problem Solvers thread. Any help on this issue would be greatly appreciated!
MarkBoucher
Honored Contributor
I downloaded your data. I projected the streams layer to the same coordinate system a you dem and changed the project on the data frame to that same projection. I ran the dem reconditioning using the dem and the reprojected streams dataset and it ran without error.
Mark
MarkBoucher
Honored Contributor
Your raster's coordinate system is:
               USA_Contiguous_Albers_Equal_Area_Conic_USGS_version, WKID: 102039 Authority: ESRI
Your polyline layer coordinate system is:
               GCS_North_American_1983, WKID: 4269 Authority: EPSG
Your first step is to choose the coordinate system for your project and reproject the data to the same coordinate system.
Mark
