I downloaded your data. I projected the streams layer to the same coordinate system a you dem and changed the project on the data frame to that same projection. I ran the dem reconditioning using the dem and the reprojected streams dataset and it ran without error.
Mark
Yup, that fixed it! Thank you!
Your raster's coordinate system is:
USA_Contiguous_Albers_Equal_Area_Conic_USGS_version, WKID: 102039 Authority: ESRI
Your polyline layer coordinate system is:
GCS_North_American_1983, WKID: 4269 Authority: EPSG
Your first step is to choose the coordinate system for your project and reproject the data to the same coordinate system.
I am similarly having issues with the DEM reconditioning tool. I have tried all of the suggested solutions, including those found in the Arc Hydro Problem Solvers thread. Any help on this issue would be greatly appreciated!
I un- and re-installed Arc Hydro Tools and tried to run it again. When trying to "Set Target Locations", which seems simple enough, I get a "tool not valid" error. None of the tools function, various errors are returned from all of them.
how we can invite them to this thread?
Messages Executing: DEMReconditioning elev_cm.tif NHDFlowline 5 10 1000 C:\Users\<msg>0;Start Time: Wed Oct 31 17:45:10 2012 ERROR 000816: The tool is not valid. Failed to execute (DEMReconditioning). Failed at Wed Oct 31 17:45:10 2012 (Elapsed Time: 0,00 seconds) Failed at Wed Oct 31 17:45:10 2012 (Elapsed Time: 0,00 seconds)
Messages Executing: DEMReconditioning "C:\Users\<msg>0;Start Time: Wed Oct 24 12:39:00 2012 Making buffer constant grid .. Making smooth constant grid .. Making sharp constant grid .. ERROR 010024: Error during conversion. Failed to execute (DEMReconditioning). Failed at Wed Oct 24 12:39:01 2012 (Elapsed Time: 1,00 seconds) Failed at Wed Oct 24 12:39:01 2012 (Elapsed Time: 1,00 seconds)
Executing: DEMReconditioning "C:\Users\<msg>0;Start Time: Wed Oct 24 14:36:19 2012 <msg>2;Failed to execute (DEMReconditioning). Failed at Wed Oct 24 14:36:19 2012 (Elapsed Time: 0,00 seconds) Failed to execute (DEMReconditioning). Failed at Wed Oct 24 14:36:19 2012 (Elapsed Time: 0,00 seconds)
MBoucher21, I have the same error that kimcarlson posted... What might be the case? Using just tutorial data for ArcHydro 2.ArcGIS 10.1, latest ArcHydro for 10.1 from the ftp
I did not have the OBJECTID field in my feature class.
