DEM Reconditioning Error in ArcHydro Tools Tutorial
3261
12-24-2012 05:06 AM
GeospatialTechnology
I am using ArcGIS 10.1 SP1 for Desktop and have recently installed ArcHydro Tools 10.1.
I am trying to teach myself how to use ArcHydro and have just started the ArcHydro Tools 2.0 Tutorial.
The first steps have gone okay however when running the DEM Reconditioning tool I get the following error:
"ERROR 010024 Error during conversion."
I have done everything as outlined in the tutorial so far.
Is there a reason this is happening?
ChristineDartiguenave
Assuming that you are using the latest versions (i.e. not an issue with OID/OBJECTID), and that you input stream is not a shapefile, there is a potential bug when the input dem is stored in a file geodatabase. Current workaround is to store the input dem on the disk. When the dem is in a gdb, some of the intermediate data is being cleaned up too soon. We will look into it.
Christine Dartiguenave
Esri Water Resources Team
