Catchment Delineation
3019
07-01-2014 11:57 PM
ketakiagarwal
I am processing in GeoHMS to create a watershed. The catchment grid created has gaps in between.
Surprisingly, in my first attempt of preprocessing,this issue didnot occur.
later, I had to reshape the dem for outlet point, and since then, there has been gaps in the catchment grid.
I have even burned the streams into the dem, and have done a no.of trials by adjusting the threshold area, but still the issue persists
Kindly help. I am using ArcGIS 10, and Aster dem.
MarkBoucher
Honored Contributor
Did you fill sinks? Failing to fill sinks can result in gaps like this.
ketakiagarwal
yes..i have done that. twice..Before and after  burning the streams .
The surprsing fact is, it didnot happen in the first attempt .. Am guessing its the dem issue. because, its working fine with global dem.
