Error while using ArcHydro in Stream Definition and Stream Segmentation
4769
07-08-2014 02:35 AM
Ing_SiongPhan
Hi, I am using ArcHydro for watershed delineation. I followed the steps in the tutorial. However, I faced errors with step "Stream Definition" and "Stream Segmentation" while using ArcHydro.
1) According to the tutorial, the result of Stream Definition should have Value "1", but my results showed 2 Value with "0" and "0".
2) Then, the "Stream Segmentation" result should have attribute table, but there is no attribute table in my result.
Data that I am using is SRTM. I am using ArcGIS 10.2 trial version with ArcHydro 10.2.
Image 1 showed the error of step Stream Definition.
Can anyone help for this? Thanks
