Bringing HEC-RAS 4.1 results into HAZUS 2.0
2307
06-13-2012 10:50 AM
LindseyLangsdon
I was given some HEC-RAS 4.1 output FLT files to use in HAZUS 2.0.  Every time I try to bring in one of the FLT files I get an error message that reads "The FLT file cannot be imported because the associated floodplain boundary shapefile (FloodMap.shp) cannot be found."  I was told this could be a HAZUS 2.0 bug.  Has anyone else had this problem, and if so how did you fix it?  There are no associated FloodMap.shp files.
