Arc Hydro Pro - 'RuntimeError: Object: Error in getting parameter as text'
1486
10-27-2017 02:34 AM
StavrosKarapanos
I tried to run Create Drainage Line Structures Script from Arc Hydro at ArcGIS pro and I got the following message: "Running script CreateDrainageLineStructures...
('line 2263', 'C:\\Program Files\\ArcGIS\\ArcHydroPro\\Scripts\\ArcHydro\\createdrainagelinestructures.py', 'RuntimeError: Object: Error in getting parameter as text')".
What should be done?
Thank you in advance
ChristineDartiguenave
The underlying code was updated and the UI is missing one parameter (EditPoint). This is fixed in the latest version:
http://downloads.esri.com/archydro/ArcHydro/Setup/Pro/ArcHydroPro2.0.8/
Christine Dartiguenave
Esri Water Resources Team
StavrosKarapanos
Thank you very much. That subroutine works. Now I am going to verify the whole procedure for the same basin so I could be sure that all the nessecary features have been populated as they should. Thank you again
