Arc Hydro Installation - Versions and Documentation
67305
36
08-04-2014 07:11 AM
ChristineDartiguenave
Arc Hydro Documentation
https://community.esri.com/t5/water-resources-documents/tkb-p/water-resources-docs
Arc Hydro versions available
ArcGIS Version
Arc Hydro Version
ArcGIS Pro
https://www.esri.com/en-us/industries/water-resources/arc-hydro/downloads#arc-hydro-for-arcgis-pro
ArcMap
9.3 - 10.8.x
https://www.esri.com/en-us/industries/water-resources/arc-hydro/downloads#arc-hydro-for-arcmap
Notes
You need to download the following patches:
Christine Dartiguenave
Esri Water Resources Team
MichelleTanner
New Contributor III
Thank you Christine, I will move forward with ArcMap
AlexTim
Hi Christine, I just purchased ArcGIS and the ArcHydro Tools download link for ArcMap 10.8 isn't available and the present ones aren't backwards compatible in ArcMap 10.8. I'm new to ArcGIS Pro with most of my projects in ArcMap. Kindly help. A download link for Arc Hydro Tools 10.8 will be highly appreciated.
BenRogers
Is there a way to silently install the MSI for ArcGIS Pro without receiving the Esri ArcGIS Add-In Installation Utility prompt to approve the install? I've tried using the /qn switch on the install command, but I'm still receiving the prompt. We have a few dozen computers that will be receiving this add-in and we'd like to deploy it silently via Microsoft Endpoint Configuration Manager.
Any version after 2.0.194 included will be silent:
http://downloads.esri.com/archydro/ArcHydro/Setup/Pro/ArcHydroPro2.0.194/
BenRogers
Thank you, Christine. That solved the issue!
HazelOliveParmes
New Contributor II
Hi, may I ask what particular ArcHydro should I download for ArcGIS Pro v.2.5.0? Thank you!
SeanFadum1
New Contributor III
Hi Christine,
Is there a version of ArcHydro that will run in the ArcGIS Pro 3?  With the change in code for this release, I suspect that the old versions will not work.
Sean
