the best path
1200
04-17-2011 04:31 AM
zouheirsalman
hi
If I have a set of points, for example: 25 points are specific locations in a city and we want to go to these points . how can I choose the better path  for it in a better time
thanks for you
Tags (1)
GregSutherland
Check out ESRI's Network Analyst product.
JaySandhu
To find best sequence to visit a set of stops is called the Traverlling Salesman Problem.
You can use the Network Analyst Route Solver. After loading your 25 stops, bring up the properties of the route solver and on the Analysis Settings tab, click on the option to Reorder Stops to Find Optimal Route.
More info here:
http://help.arcgis.com/en/arcgisdesktop/10.0/help/index.html#/Route_analysis/004700000045000000/
Regards,
Jay Sandhu
MikeFlores
When will ArcLogistics Navigator support iOS and Android?
