Point file of roadway intersections??
1109
06-21-2011 01:16 PM
MichaelMiller2
Is there a way in ArcGIS 10 to generate a point file of intersecting roads (lines)??  I seem to remember that the old command line ArcINFo had a command that would perform this rather easily......have not been able to locate anything in Arc 10 that will accomplish this.  Am I missing something here?
Michael Miller
Tags (1)
Scott_atEsri
You can use the feature "verticies to points tool" GP, and select the "both ends" option.
Or create a topology lines must not intersect and export all of the errors as points.
Also, consider using the "integrate" tool on the topology toolbar for splitting up your road network in an intermediate processing dataset.
MichaelMiller2
Thanks Scott.  I did find the verticies to points tool and it worked great.  Appreciate the topology suggestion.
Thanks again.
Michael Miller
