python field calculator issue
6675
8
01-27-2011 06:40 AM
by Anonymous User
Not applicable
Original User: frankv3
i am having trouble calculating a string field named Plat_Link in a polygon feature class that has an integer field named MAP_BOOK and an integer field name PAGE
i tested this code in IDLE and it worked fine if MAP_BOOK and PAGE were set (see picture), but it will not work in the field calculator, an error of 000989 is returned
the code was tried both of these ways (first way in attached picture):
MapNum = str(!MAP_BOOK!)
PageNum = str(!PAGE!)
if len(PageNum) == 1:
PlatLink = "\\\\" + "Covsdesrv" + '\\' + "GIS Common" + '\\' + "Plats" + '\\' + "00" + MapNum + '\\' + "00" + MapNum + "000" + PageNum + ".TIF"
elif len(PageNum) == 2:
PlatLink = "\\\\" + "Covsdesrv" + '\\' + "GIS Common" + '\\' + "Plats" + '\\' + "00" + MapNum + '\\' + "00" + MapNum + "00" + PageNum + ".TIF"
elif len(PageNum) == 3:
PlatLink = "\\\\" + "Covsdesrv" + '\\' + "GIS Common" + '\\' + "Plats" + '\\' + "00" + MapNum + '\\' + "00" + MapNum + "0" + PageNum + ".TIF"
AND
if (!PAGE!) = 1:
PlatLink = "\\\\" + "Covsdesrv" + '\\' + "GIS Common" + '\\' + "Plats" + '\\' + "00" + str(!MAP_BOOK!) + '\\' + "00" + str(!MAP_BOOK!) + "000" + str(!PAGE!) + ".TIF"
elif (!PAGE!) = 2:
PlatLink = "\\\\" + "Covsdesrv" + '\\' + "GIS Common" + '\\' + "Plats" + '\\' + "00" + str(!MAP_BOOK!) + '\\' + "00" + str(!MAP_BOOK!) + "00" + str(!PAGE!) + ".TIF"
elif (!PAGE!) = 2:
PlatLink = "\\\\" + "Covsdesrv" + '\\' + "GIS Common" + '\\' + "Plats" + '\\' + "00" + str(!MAP_BOOK!) + '\\' + "00" + str(!MAP_BOOK!) + "0" + str(!PAGE!) + ".TIF"
any help appreciated
ChrisMathers
Im not sure why that isnt working but for starters you should try string substitution instead of concatentation and raw strings so you dont have to excape all those'\'.
http://docs.python.org/release/2.6.6/library/stdtypes.html#string-formatting-operations
PlatLink = r"\\Covsdesrv\GIS Common\Plats\00%s\00%s000%s.TIF"%(MapNum,MapNum,PageNum)
by Anonymous User
Not applicable
thank you for the tip, i'm just learning to use this scripting language and any help is much appreciated
by Anonymous User
Not applicable
it is still not calculating in ArcMap, reports the Error 000989 - Python Syntax Error , this is the calculation code (saved out)
PlatLink = r"\\Covsdesrv\GIS Common\Plats\00%s000%s.TIF"%(MapNum,MapNum,PageNum)
PlatLink = r"\\Covsdesrv\GIS Common\Plats\00%s00%s.TIF"%(MapNum,MapNum,PageNum)
PlatLink = r"\\Covsdesrv\GIS Common\Plats\00%s0%s.TIF"%(MapNum,MapNum,PageNum)
__esri_field_calculator_splitter__
PlatLink
it runs fine in the IDLE window as before, anyone know what i'm doing wrong?
PatrickOMalley
The code you are showing does not show indentation of the action parts of the if statements. Python is very picky about white space and there must be indentation. I'm certain when you typed it into IDLE it supplied the indentation for you automatically.
Try this
    PlatLink = r"\\Covsdesrv\GIS Common\Plats\00%s000%s.TIF"%(MapNum,MapNum,PageNum )
PatrickOMalley
I know I put 4 spaces in front of every line that started with PlatLink, but they don't show up in my submittal to the forum. Maybe your indentation is fine and the forum software strips off excess whitespace.
DanPatterson_Retired
You have to put code in the code blocks in the html editor, select the # tool from the message posting toolbar, paste your code and the proper indentation will be maintained as in this nonsence example
names = ["Obi", "Bob", "Billy"]
for name in names:
  if name == "Obi":
    print name, "is ", True, "a", "Jedi master"
  else:
    print name, "is not a Jedi master"
don't forget to copy, compile and run the script to see if it works 🙂
by Anonymous User
Not applicable
so, the field names go at the bottom in the Expression box and then the result goes above in the Code Block box
it's almost the opposite of how the VBA calculator expressions ran
this is what works for us to calculate hyperlinks based on two fields:
Code Block:
def SetLink(map,page):
if len(str(page)) == 1:
     num0 = "000"
elif len(str(page)) == 2:
     num0 = "00"
elif len(str(page)) == 3:
     num0 = "0"
return r"\\Covsdesrv\GIS Common\Plats\00%s\00%s%s%s.TIF"%( str(map), str(map), num0, str(page))
Expression:
SetLink( !MAP_BOOK!, !PAGE! )
NiklasNorrthon
Seems unecessarily complicated. Simpler version follows:
def SetLink(map, page):
    return r"\\Covsdesrv\GIS Common\Plats\%03d\%03d%04d.TIF % (map, map, page)
