Arcgis10: Python error : RuntimeError : method datasetType does not exist
5086
6
02-01-2011 01:47 AM
XavierMauclaire
Hi
I develop python script with eclipse.
When i run the code under eclipse ou  with the dos command line ), i get the error "function not found"...
This code runs well under the python console of arccatalog
I set the PYTHONPATH with the arcgis 10 bin an arccpy directories .. no issue !!
Please Help !!! je craque !!!
My code :
import arcpy
if __name__ == '__main__':
    zPath = "c:/test.shp"
    print"toto"
    pDesc = arcpy.Describe(zPath)
#    error here RuntimeError: DescribeData: Method DatasetType does not exist
    print pDesc.DatasetType
# and here
    pExtent = pDesc.Extent
# and here
    print "Extent of shape :\nXMin: %f, YMin: %f, \nXMax: %f, YMax: %f" % \
        (pExtent.XMin,pExtent.YMin,pExtent.XMax,pExtent.YMax)
# and here
    pSr = pDesc.spatialReference
    print pSr.name
by Anonymous User
Not applicable
Try setting your env.workspace
import arcpy
from arcpy import env
    env.workspace = 'c:/temp/python'
    zPath = "c:/temp/python/test.shp"
    print"toto"
    # and here
    # and here
    # and here
    print pSr.name
You should get something like:
C:\Temp\Python>python test.py
toto
FeatureClass
Extent of shape :
XMin: 1727760.654081, YMin: 657671.252142,
XMax: 1733764.605903, YMax: 662427.894069
NAD_1983_StatePlane_Tennessee_FIPS_4100_Feet
C:\Temp\Python>
by Anonymous User
Not applicable
Original User: Xavier
Yes il should sir..
I get this when i run the script from the arccatalog python console
But i get this when i use the dos command line
toto
toto
  File "C:\Users\xmauclaire\Documents\Etudes\GeoDoc_DI104\Dev\Python\pygeodoc\src\Setbounds.py", line 24, in <module>
    print pDesc.datasetType
RuntimeError: DescribeData: Method datasetType does not exist
Any idea ?
regards
by Anonymous User
Not applicable
Did you add/modify what I posted?
Primarly
Set to your environment.
by Anonymous User
Not applicable
Yes sir i did that and got the same result !
On the other hand i can get defaults describe attributes (baseName, file etc) but not other specific attributes.
if with the debuger i do a  hasattr(pDesc, "datasetType"), the answer is false...
amazing isn't it ?
regards
by Anonymous User
Not applicable
Then I don't know. Two things I would try:
1) Add C:\Python26\ArcGIS10.0 to your system path and execute the .PY  the way I did.
2) Put your code in a folder that does not contain spaces.  Something like C:\temp for testing.  Make it simple until you can figure out what's throwing the error.
You don't have multiple versions of Python your box do you?
by Anonymous User
Not applicable
The Path variable is ok
I'm going to test your idea.
Thanks for all.
regards
