Bearing technology standards
788
01-25-2011 09:40 PM
sugarmike
Bearing types, structure, precision grade is different, its processing technology will be different.
But overall, usually after forging, turning, heat treatment, grinding, ultra precision (or polishing and grinding, etc.)
From the blank is, bearing at this great materials, pipe materials, forgings, cold rolling material has, after heat treatment process is necessary, then grinding machining, and some of the heavy production in recent years a large (more than 2000mm) bearing diameter, after the CNC lathe machining, the essence of the car after can serve as end processing, anyhow, bearing process usually have the four or five process and, with its types, structures, precision grades of different, processing technology will have bigger difference.
Tags (1)
