How to add parameter descriptions in the right pane of a script tool dialog box
5967
08-09-2012 03:01 PM
DavidNagel
This is a little hard to explain and I'm not sure what search terms to use, so I can't find help.
I've created a custom toolbox and added a Python script to the toolbox. I've also gone through the Properties dialog for the script and created all of the necessary input parameter boxes and pulldowns, etc.
So now I have a dialog box for users to fill out all of the input parameters when I double click the script. All of my input boxes are in the left pane of the dialog box and in the right pane is a space for a description for each input box. When I click on my first input box for example (Workspace location), in the right pane it says "Workspace location" and then "No description available".
How do I enter the description information? I can't seem to find the instructions anywhere. The instructions under "Documenting tools" in the Help don't seem to work for this application. Can anyone help?
Thank you so much - Dave
SolomonPulapkura
All you need to do is edit the tools metadata in ArcCatalog "Description" tab. You have the option to input details for each parameter in there.
by Anonymous User
Not applicable
Original User: dnagel
That's awesome. Did it. Thank you Solomon!
