Bugs in script to populate an empty attribute field
4488
08-16-2013 02:36 PM
by Anonymous User
Not applicable
Original User: sellingfloe
Here is a copy of my script.
[ATTACH=CONFIG]26766[/ATTACH]
I am attempting to populate a blank field (Veg_Height) in my shapefile attribute table with text of my own choosing depending on the value in field Class_name.
e.g. if Class_name = "Grass", change the blank Veg_Height field to "Short", if Class_name = "Trees", change the blank Veg_Height field to "Tall" etc.
Unfortunately, at the moment, I keep getting errors when I try to run this in model builder. Can anyone suggest any changes I could make?
Thanks 🙂
AmyKlug
Thanks 🙂
I also might try writing your if statement like this:
if row[0] == "Trees":
    row[1] = "Tall"
EDIT: Deleted first comment
by Anonymous User
Not applicable
Original User: msayler
The '=' is used for assignment. Since you're doing a comparison, you need to use the 'equal to' operator instead, '=='.
i.e.
if row[0] == "Grass":
    row[1] = "Short"
by Anonymous User
Not applicable
Original User: mzcoyle
As Amy and Matt pointed out, you are using the wrong equal operator for conditionals. Another option is to use a dictionary which can remove the need for conditionals completely, as well as making your code more easily extensible if you plan on adding additional classifications in the future.
curs_dict = {
    "Grass": "Short",
    "Trees": "Tall",
    "Urban": "N/A"}
for row in cursor:
    row[1] = curs_dict[row[0]]
    cursor.updateRow(row)
KerryThomas
Thanks so much!
by Anonymous User
Not applicable
Original User: curtvprice
[thread=48475]How to post Python code[/thread]
