Solution 1.1 - sample data tracing error - No valid subnetwork controllers found
2142
05-28-2021 11:59 AM
VHolubec
Hello,
I just want to ask, if network controllers are missing on sample data on version 1.1 intentionally?
I am trying to trace upstream to switch from NIU as described in Task, but in version 1.1 I am getting the error - No valid subnetwork controllers found. The same tracing on version 1.0 works fine.
I know that in the storymap there is a note that as a first steps the creation of subnetwork controller is needed - please could you add also a Task or more detailed steps for this step there?
Thank you,
Vladimir
Vladimir
by Anonymous User
Not applicable
Hi Vladimir,
All the elements in the sample data are fully connected. I think it might be a wrong "Trace Starting Point". Make sure you expand the NIU, then the Connector Group, then select and add the Connector as the starting point.
by Anonymous User
Not applicable
Hi Vladimir,
VHolubec
Hi @Anonymous User
It seems I had a corrupted project.
Thank you for help.
Vladimir
Vladimir
