Hello
I tried to add in ommunications Data Management for ArcGIS Enterprise 1.1 Preview the "Medium Converter: Fiber to Coax", which @Anonymous User showed in the video here: https://web.bd.esri.com/utilities/telco/Videos/CDM4AE/CDM4AE_player.html (the video is for the version 1 of the solution).
In version 1.1 of the solution I search to the same place and try to add to "Contains" new the item, but I wasn´t able to find it in available devices.
Is this missing there becuase it´s just preview, or what is the workflow how this object can be added?
Thank you,
Vladimir
Hi Vladimir,
Great finding on the changes on network type transitions!
In the v1.1 model, we have removed the Medium Converter equipment, and the network type transition will be reflected by the connector types contained within the device.
Let me show you an example in the sample data (Early Preview). Here we have a fiber-to-coax transition point, which we can use any device based on your engineering guideline and network architecture. In this case, I am using a Hub Terminator which contains a Patch Panel Chassis (for internal connection), a fiber connector group (incoming junctions from the fiber cable), and 3 coax connector groups (downstream junctions to the coax cables).
This design will give us flexibility in modeling complex equipment and network conversion. You can place different types of chassis to model the original "medium converter" behavior, using splitters, patch panels, amplifiers, and other equipment to show more detail about what is going on within the conversion point.
Hopefully, this information is helpful to you!
Hi Vladimir,
For the two questions:
Hi Vladimir,
Hi ,
thank you very much for clarification! Just a two additional questions:
1) Is there other way how to add object to container than via context menu -> Add new to container (some sideload/batch sideload)?
2) The data seems to be different than sample data for V1 - I don´t know what I am doing wrong, but I tried the tracing workflow from the video, and there I am getting error - No valid subnetwork controllers found. Is something missing in the preview sample data or am I missing some step - I recorded my steps to attached video?
Thank you.
Vladimir
Hi Vladimir,
Thank you @Anonymous User for help !
