Can we already create inspection records in Survey123 in a releated table to an (existing) asset feature?
4218
03-07-2016 07:21 AM
Gertvan_Dijk
In inspection and maintenance processes the actual assets are already there and with every inspection or maintenance task you create a new entry in a related table to the feature class of the asset. Is this workflow of entering new records related to a feature already supported in Survey123? If not is it planned to be supported?
BrianBaldwin
Survey123 for ArcGIS
Brian Baldwin, Esri Inc., Lead Solution Engineer
https://www.linkedin.com/in/baldwinbrian
