WebTiledLayer does not show on the map
886
03-12-2025 12:41 PM
CristhianSanchez
Hello,  we are trying to render XYZ map layers using WebTiledLayer but we noticed that when the URL template contains a .webp extension the layer has the “Loaded” status but does not render on the map, however, by replacing the .webp extension in the URL template by .png, the map layer works:
Does not work:
https://cartodb-basemaps-a.global.ssl.fastly.net/light_all/{level}/{col}/{row}.webp
Works:
https://cartodb-basemaps-a.global.ssl.fastly.net/light_all/{level}/{col}/{row}.png
We wonder if this is expected or if there is any approach to solve this. Thanks in advance.
Tags (1)
PhilipGruenler
This is expected. We do not currently support the webp image format for web tiled layers. If you would like it supported in the future, please log an idea on the ArcGIS Maps SDKs Native Ideas board. Thanks for you question.
