EXC_BAD_ACCESS (KERN_INVALID_ADDRESS) in CustomTiledLayer.init(tileInfo:fullExtent:dataProvider:)
655
08-21-2024 02:36 PM
MariaPaulaGomezP
We are experiencing a crash with the CustomTiledLayer file
we got this information:
Crashlytics:
Crashed: com.apple.main-thread
0  ArcGIS                         0x30780c closure #3 in CustomTiledLayer.init(tileInfo:fullExtent:dataProvider:) + 70 (CustomTiledLayer.swift:70)
1  ArcGIS                         0x1e7ff0 closure #1 in LayerTileClosureEvent.setupCoreCallback() + 53 (LayerTileClosureEvent+Generated.swift:53)
2  ArcGIS                         0x1b0668 partial apply for thunk for @escaping @callee_guaranteed (@in_guaranteed TileKey) -> () + 2920 (<compiler-generated>:2920)
3  ArcGIS                         0x1e7f34 coreCallback #1 (userData:tileKey:) in LayerTileClosureEvent.setupCoreCallback() + 49 (LayerTileClosureEvent+Generated.swift:49)
4  CoreArcGIS                     0x8260c4 esri::common::Slot<void (esri::common::Request_delegator const&, esri::tile::Tile_key const&)>::target_model<void esri::common::Signal<void (esri::common::Request_delegator const&, esri::tile::Tile_key const&)>::connect<std::__1::function<void (void*, esri::tile::Tile_key const&)>>(void*, std::__1::function<void (void*, esri::tile::Tile_key const&)>&&) const::'lambda'(esri::common::Signal_context<void (esri::common::Request_delegator const&, esri::tile::Tile_key const&)>, std::__1::function<void (void*, esri::tile::Tile_key const&)>&&, auto&&...)>::invoke(void const*, esri::common::Request_delegator const&, esri::tile::Tile_key const&) + 4986736
5  CoreArcGIS                     0x19b7dd4 esri::common::signal_detail::Signal_base::notify_(esri::common::Function_ref<void (esri::common::signal_detail::erased_target_base&)> const&) const + 23409792
6  CoreArcGIS                     0x9c7f34 esri::geoview::Tile_request_callback::cancel_request(int, int, int) + 6698464
7  CoreArcGIS                     0xbf4068 esri::map_renderer::Tile_provider::erase_dst_tile_(std::__1::__hash_map_iterator<std::__1::__hash_iterator<std::__1::__hash_node<std::__1::__hash_value_type<esri::tile::Tile_key, std::__1::shared_ptr<esri::map_renderer::Geo_tile>>, void*>*>>) + 8976148
8  CoreArcGIS                     0xbf49ac esri::map_renderer::Tile_provider::clean_dst_tiles_(esri::map_renderer::Clean_type) + 8978520
9  CoreArcGIS                     0xbf48b4 esri::map_renderer::Tile_provider::prepare(esri::map_renderer::Tile_view_state const&) + 8978272
10 CoreArcGIS                     0xc31a88 esri::map_renderer::Data_tile_provider::prepare(esri::map_renderer::Tile_view_state const&) + 9228596
11 CoreArcGIS                     0xcb9090 esri::map_renderer::Service_tile_provider::prepare(esri::map_renderer::Tile_view_state const&) + 9783100
12 CoreArcGIS                     0xbf4904 esri::map_renderer::Tile_provider::prepare(esri::map_renderer::Tile_view_state const&) + 8978352
13 CoreArcGIS                     0xcb64a8 esri::map_renderer::Resampled_tile_provider_base::prepare(esri::map_renderer::Tile_view_state const&) + 9771860
14 CoreArcGIS                     0xcb15ac esri::map_renderer::Raster_tile_layer::prepare(std::__1::shared_ptr<esri::map_renderer::Drawable::Render_properties>&, std::__1::shared_ptr<esri::map_renderer::Display_properties> const&) + 9751640
15 CoreArcGIS                     0xca79f8 esri::map_renderer::Map::on_pulse_() + 9711780
16 CoreArcGIS                     0xca6e94 esri::map_renderer::Map::pulse() + 9708864
17 CoreArcGIS                     0xe5a3c RT_GeoView_pulse + 44
18 ArcGIS                         0x3ff748 specialized GeoMetalView.Coordinator.draw(in:) + 259 (GeoCommonView.swift:259)
19 ArcGIS                         0x3f9948 @objc GeoMetalView.Coordinator.draw(in:) + 29700 (<compiler-generated>:29700)
20 MetalKit                       0x74b4 -[MTKView draw] + 160
21 MetalKit                       0x73f4 -[MTKViewDisplayLinkTarget draw] + 32
22 QuartzCore                     0xd0ecc CA::Display::DisplayLinkItem::dispatch_(CA::SignPost::Interval<(CA::SignPost::CAEventCode)835322056>&) + 48
23 QuartzCore                     0xcf230 CA::Display::DisplayLink::dispatch_items(unsigned long long, unsigned long long, unsigned long long) + 876
24 QuartzCore                     0xcedd0 CA::Display::DisplayLink::dispatch_deferred_display_links(unsigned int) + 352
25 UIKitCore                      0xb776c _UIUpdateSequenceRun + 84
26 UIKitCore                      0xb73b0 schedulerStepScheduledMainSection + 172
27 UIKitCore                      0xb8254 runloopSourceCallback + 92
28 CoreFoundation                 0x56834 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE0_PERFORM_FUNCTION__ + 28
29 CoreFoundation                 0x567c8 __CFRunLoopDoSource0 + 176
30 CoreFoundation                 0x54298 __CFRunLoopDoSources0 + 244
31 CoreFoundation                 0x53484 __CFRunLoopRun + 828
32 CoreFoundation                 0x52cd8 CFRunLoopRunSpecific + 608
33 GraphicsServices               0x11a8 GSEventRunModal + 164
34 UIKitCore                      0x40a90c -[UIApplication _run] + 888
35 UIKitCore                      0x4be9d0 UIApplicationMain + 340
36 Fulcrum                        0x915c main + 13 (main.m:13)
Instabug:
SIGTRAP : Crash due to signal: SIGTRAP(TRAP_BRKPT) at 1087d31d0
Queue 18: com.apple.root.user-initiated-qos.cooperative
concurrent
CustomTiledLayer.__allocating_init(tileInfo:fullExtent:dataProvider:) (CustomTiledLayer.swift:42 )
0    ArcGIS                                   0x1087d31d0     CustomTiledLayer.__allocating_init(tileInfo:fullExtent:dataProvider:) (CustomTiledLayer.swift:42)
1    Fulcrum                                  0x104950824     closure #1 in variable initialization expression of MapLayerLoaderImpl.customTiledLayer (MapLayerLoaderImpl.swift:46)
2    Fulcrum                                  0x104953b84     MapLayerLoaderImpl.mbTilesLayer(_:) (MapLayerLoaderImpl.swift:250)
3    Fulcrum                                  0x104952078     MapLayerLoaderImpl.loadLayer(for:) (MapLayerLoaderImpl.swift:121)
4    libswift_Concurrency.dylib               0x1b29f2764     swift::runJobInEstablishedExecutorContext(swift::Job*) + 435
5    libswift_Concurrency.dylib               0x1b29f39c8     swift_job_runImpl(swift::Job*, swift::ExecutorRef) + 71
6    libdispatch.dylib                        0x1af567894     _dispatch_root_queue_drain + 391
7    libdispatch.dylib                        0x1af56809c     _dispatch_worker_thread2 + 155
8    libsystem_pthread.dylib                  0x2045078f8     _pthread_wqthread + 227
9    libsystem_pthread.dylib                  0x2045040cc     start_wqthread + 7
We would want to know if, with these lines of code, you have enough information to understand the problem or know what we can do.
rolson_esri
Esri Alum
What version of the Swift Maps SDK are you using? Can you try to reproduce this with 200.5? Some improvements were made to thread safety in 200.5 which might alleviate this issue.
KaraKay
Hi, we're using 200.6.0
