Issue Identifying Single Features in Clustered Layers using identifyLayers
231
6
3 weeks ago
t-schaal
Hello everyone,
We're currently using the identifyLayers function from MapViewProxy to identify features in our layers. This generally works well, but we've noticed an issue with layers where clustering is enabled:
Clicking on a cluster returns the expected result using identifyLayers.
Clicking on a single, non-clustered feature does not return a result.
Is this an issue of identifyLayers, or is there a better way to reliably identify all features, including non-clustered ones, in clustered layers?
We considered using identify(on layer: ArcGIS.Layer) as shown in this example . However, since we have multiple layers, calling this function repeatedly for each layer is not ideal.
Any suggestions or best practices would be appreciated—thanks in advance!
t-schaal
Thanks! I found the issue. We were setting maximumResultsPerLayer to nil, which caused problems identifying single features. Leaving it unset fixed the issue for us. 🙂
t-schaal
let result = try? await proxy.identifyLayers(...)
-> result is an empty array here if clustering is active for the layer and you click on a single feature that is not clustered
Ting
by Esri Regular Contributor
Thanks for reaching out. Can you let me know the environment and versions you are using? Specifically, are you building with Xcode 26.0 when you see this problem? Thanks.
OS version:
Xcode version:
Target type: (iPhone, Simulator, Mac Catalyst)
Target version:
SDK version:
t-schaal
OS version: currently iOS 26 but it also occured on older OS versions
Xcode version: 16.4
Target type: iPhone
Target version: iPhone 15 Pro
SDK version: 200.8.0
Ting
Want to check in if you have received my DM and been able to run the snippet.
Just want to check, are you setting the `maximumResult` count on the identify method?
t-schaal
Ting
Thanks for the update. This might be a bug and we are looking into fixing it on our end. Glad it worked out.
