DownloadPreplannedOfflineMapJob gets stuck downloading preplanned maps
720
04-11-2024 11:56 PM
manishfueled
I have an Webmap for which I have created a couple of preplanned offline areas and when I try to load the offline maps using DownloadPreplannedOfflineMapJob, the download is usually very slow and at times get stuck at 15% in most cases before it starts again after a few minutes.
Any ideas on what could be causing this?
Tags (3)
Ting
by Esri Regular Contributor
Hi, would you mind sharing the version of the SDK you are using?
In 200.1 we had a bug that prevents more specific progress being reported between 15% and 92%, and that issue should have been fixed in 200.3 and above versions (issue 4032 for internal tracking). Please share more details, so we can debug further - maybe it's something that we still need to fix. 👀
In terms of slow download, it could be related to large amount of tiles and data. Try a more "zoom-in" scale and see if it improves, say level of detail around 20 - 21. If it still takes more than 1 minute in a normal network, it would be abnormal.
