Arcgis single sign-on not working properly.
1366
09-24-2024 07:39 AM
DuanePfeiffer
Whenever my code tries to sync with arcgis online, it prompts the user to login.  It used to use the SAML single sign-on.  I believe it has something to do with this: https://www.esri.com/arcgis-blog/products/trust-arcgis/administration/action-required-arcgis-online-...
What do I need to do in my code to get this working again?
NimeshJarecha
Hi @DuanePfeiffer,
Did you try the steps outlined in the blog post to reconfigure the SAML on your organization account? Can you please post your code and steps to follow to reproduce the issue?
Thank you.
Regards,
Nimesh
DuanePfeiffer
The problem has been solved.  It was caused by following the best practices outlined in the post and not my code.  Basically, nobody could log into arcgis.com using SAML.  My network administrator reverted his changes and things are working now.  So the above blog post seems to have some problems.
NimeshJarecha
Hi @DuanePfeiffer,
I'm glad to hear that the issue has been resolved! Could you please share the details or steps from the blog that led to the problem? Understanding this will help us investigate further and make any necessary corrections.
Thank you!
Regards,
Nimesh
