Adding tile layer from tile package not showing in map.
1401
01-31-2023 09:42 AM
DuanePfeiffer
Using 100.x codebase as an example, I'm trying to add imagery to my map but am not seeing the layer show up.  Source of imagery is a .tpkx,  My map is loaded from a .mmpk
EDIT: Added layer.load()... still don't see on map.
    func ToggleImagery() async {
        do {
            if showImagery == true {
                let sourceURL = TPUDFacilityInspectorApp.documentsURL.appendingPathComponent(K.imageryTilePackageName)
                print(sourceURL)
                if FileManager.default.fileExists(atPath: sourceURL.path(percentEncoded: true)) {
                    appData.imageryLayer = ArcGISTiledLayer(url: sourceURL)
                    try await appData.imageryLayer.load()
                    appData.map.insertOperationalLayer(appData.imageryLayer, at:0)
            } else {
                if appData.imageryLayer != nil {
                    appData.map.removeOperationalLayer(appData.imageryLayer)
                    appData.imageryLayer = nil
        } catch {
            ShowAlert(message: "\(error)")
DuanePfeiffer
One of our GIS guys figured it out for me.  The imagery was projected in a different system than the mobile map package.
DuanePfeiffer
dfeinzimer
Hi Duane, happy to that you've found a solution.
