Zoning Data with more than 1 variance
1062
11-05-2021 02:57 PM
by Anonymous User
Not applicable
Hi all,
I am in the process of rebuilding our Zoning map, with the intent of it being web facing, so people can click on a parcel and get the assigned Zoning designation and information.
Our Zoning Code has a few zones that have more than one variance/regulation assigned to them.
For instance, R2, has multiple regulations all with different lot widths and depths and set back requirements.
My question is this:
How best to incorporate the data from those multiple regulation Zoning designations into the attribute table, so that all 4 options are shown in the Identify window, or a pop up in the online web map.
I have attached the spreadsheet I am using to populate the new Zoning layer.
I want to avoid having to put See Ordinance in the various set back and dimension columns as this is the way the old version works.
I do have a feeling, some Planning office somewhere has done something similar to what I am thinking of doing, so the question is posed to the brain trust
Thanks in advance for your time and attention
Rick
forestknutsen1
MVP Regular Contributor
what about having the variance/regulation in a related table?
forestknutsen1
by Anonymous User
Not applicable
I have thought about this, but my question then becomes, will the relationship persist when uploaded to AGOL? Either I haven't found a good explanation on this, or I am not using the right search terms.
by Anonymous User
Not applicable
We ended up doing that, creating a spreadsheet that had all the values, and uploaded that document to AGOL, and then did a join to the Zoning data.
