Xray Excel Error
5404
10-03-2013 10:41 AM
MattKoukol
I have just installed Xray 10.2 for ArcCatalog.  I have selected a geodatabase .xml file as well as a file geodatabase.  I click the "Export GDB to XML Workspace" button, and I get an error that says:
"Unable to cast COM object of type 'Microsoft.Office.Interop.Excel.ApplicationClass' to interface type 'Microsoft.Office.Interop.Excel.Application'.  This operation fail ... (a lot of interface ID stuff)... dut to the following error: Library not registered....  Please ensure you have Microsoft Excel installed."
I do have Excel 2007 installed.
Any help resolving this issue would be greatly appreciated.
Matt
SteveGrise
Hi Matt, did you ever find a solution to this? This usually works fine, but there could be something wrong in the GDB or the Excel setup. I can take a look if you are stuck.
PaulCone
I am also getting this error.  Have Excel 2003 installed.
Paul
Paul Cone
Mapping and GIS
City of Portland, Bureau of Transportation
SteveGrise
Hi Paul, X-Ray is designed to work with Excel 2007 and higher. You might be able to get it to work with the Office Compatability Pack from http://support.microsoft.com/kb/924074 to work with the newer .xlsx formats.
Steve
MattKoukol
Once we updated, it was good.  Thanks!
