X-Ray SDE Question
2856
01-03-2013 06:16 AM
PatriciaMoehring
I exported my whole sde to an xml document (I really only wanted to export the tree feature but now notice that maybe I needed to have a dataset selected instead).  Anyway, I edited 3 domains for my tree feature and want to import them back into my sde.  However, I do not see that selection using the Import Using Geoprocessing -- I think this is what I should be using --
1. selected my xml workspace file,
2. selected the sde as the output workspace (but wonder if this is supposed to be the Xray folder holding all the xlxs)
3. not sure what selection I should be checking to get those changes back into sde?
I hope this is something I can do; I'll be very depressed if I can't!
Thanks, Patricia
ScottOppmann
Yes, you can append your new domains to your existing SDE schema.  Start by creating an XML workspace document with the changes you'd like to apply.  Then select Xray dropdown>Import Using Geoprocessing tool.  Input your XML workspace document, your SDE geodatabase and select Add Missing Domains.
When you select OK, the new domains will be imported in to your SDE schema.
Scott
