X-Ray import error
4147
05-28-2015 09:22 AM
CassidyKillian
I am having a similar error to a few topics below when I try to import a schema after I use the migration wizard.
Here is the error:
XML Import Error: Type mismatch. (Exception from HRESULT: 0x80020005 (DISP_E_TYPEMISMATCH))
When I validate my xml I get these 7 errors:
MissingClassRelationshipClassName - lrLinesToAnnoDatasetName - ParcelDimensions
MissingClassRelationshipClassName - lrParceltoCondoDatasetName - TaxParcelCondo
MissingClassRelationshipClassName - lrParceltoLineDatasetName -
MissingClassRelationshipClassName - lrParceltoPlanDatasetName -
MissingKeyRelationshipClassName - ssManholeInspection__ATTACHRELDataElementName - ssManholeInspectionFieldName - GlobalID
MissingKeyRelationshipClassName - ssManholeInspection__ATTACHRELDataElementName - ssManholeInspection__ATTACHFieldName - REL_GLOBALID
SubtypeCodeErrorDesc - DefaultSubtype Code not found in list of subtype codesSubtypeFieldName - SUBTYPEFIELDDefaultSubtype - 10
The weird thing is that all of these things are in the new xml document.  How do I fix these errors so I can import into a new database?
CassidyKillian
Now after I compare my current local government database to the latest version using the migration wizard, the output xml file is giving me this error when I try to validate it
Any ideas why the wizard would put out a bad xml?
CassidyKillian
and now this error
Im beginning to think I wont be upgrading to new LGIM.
