X-Ray for ArcCatalog for 10.4.1
5844
11
09-27-2016 06:45 AM
ChrisRumig
I just installed the latest X-Ray for ArcCatalog (v10.4)  after upgrading to ArcGIS 10.4.1 last week.  I can install the add-in, however when I attempt to export GDB to xml Workspace or open an xml document I get the following error message.
SteveGrise
************** Exception Text **************
System.IO.FileNotFoundException: Could not load file or assembly 'office, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c' or one of its dependencies. The system cannot find the file specified.
File name: 'office, Version=15.0.0.0, Culture=neutral, PublicKeyToken=71e9bce111e9429c'
at XRayArcCatalog.XRayDockableWindow.copyToXlsx(String xlsPath, String xlsxPath)
at XRayArcCatalog.XRayDockableWindow.copyAllToXlsx() in c:\Users\mike6491\_b\git\x-ray-for-arc-addins\XRayArcCatalog\xslt.cs:line 236
at XRayArcCatalog.XRayDockableWindow.openXML() in c:\Users\mike6491\_b\git\x-ray-for-arc-addins\XRayArcCatalog\xslt.cs:line 222
at XRayArcCatalog.XRayDockableWindow.btnOpenXML_Click(Object sender, EventArgs e) in c:\Users\mike6491\_b\git\x-ray-for-arc-addins\XRayArcCatalog\XRayDockableWindow.cs:line 223
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.OnMessage(Message& m)
at System.Windows.Forms.Control.ControlNativeWindow.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
WRN: Assembly binding logging is turned OFF.
To enable assembly bind failure logging, set the registry value [HKLM\Software\Microsoft\Fusion!EnableLog] (DWORD) to 1.
Note: There is some performance penalty associated with assembly bind failure logging.
To turn this feature off, remove the registry value [HKLM\Software\Microsoft\Fusion!EnableLog].
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.6.1085.0 built by: NETFXREL4STAGE
CodeBase: file:///C:/Windows/Microsoft.NET/Framework/v4.0.30319/mscorlib.dll
JTXExt
Assembly Version: 10.2.0.0
Win32 Version: 10.2.2.3239
CodeBase: file:///c:/program%20files%20(x86)/ArcGIS/WMX/desktop10.2/Bin/JTXExt.dll
ESRI.ArcGIS.Catalog
Assembly Version: 10.4.0.0
Win32 Version: 10.4.1.5686
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Catalog/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Catalog.dll
ESRI.ArcGIS.System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.System/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.System.dll
System.Drawing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
ESRI.ArcGIS.JTX
Win32 Version: 10, 2, 2, 3239
CodeBase: file:///C:/WINDOWS/assembly/GAC_MSIL/ESRI.ArcGIS.JTX/10.2.0.0__8603f16c5781c275/ESRI.ArcGIS.JTX.dll
ESRI.DADF.Core
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.4/bin/ESRI.DADF.Core.DLL
ESRI.Reviewer.Desktop
Win32 Version: 10.4.1.867
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/ESRI.Reviewer.Desktop/v4.0_10.4.0.0__49f88df635890024/ESRI.Reviewer.Desktop.dll
ESRI.Reviewer.Public.Desktop.Interop
Win32 Version: 10, 4, 1, 867
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/ESRI.Reviewer.Public.Desktop.Interop/v4.0_10.4.0.0__49f88df635890024/ESRI.Reviewer.Public.Desktop.Interop.dll
ESRI.Reviewer.Public.Engine.Interop
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/ESRI.Reviewer.Public.Engine.Interop/v4.0_10.4.0.0__49f88df635890024/ESRI.Reviewer.Public.Engine.Interop.dll
ESRI.ArcGIS.Framework
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Framework/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Framework.dll
ESRI.ArcGIS.Geodatabase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Geodatabase/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Geodatabase.dll
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
ESRI.ArcGIS.JTXUI.JTXShared
CodeBase: file:///c:/program%20files%20(x86)/ArcGIS/WMX/desktop10.2/Bin/ESRI.ArcGIS.JTXUI.JTXShared.DLL
ESRI.Reviewer.Engine.Interop
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_32/ESRI.Reviewer.Engine.Interop/v4.0_10.4.0.0__49f88df635890024/ESRI.Reviewer.Engine.Interop.dll
ESRI.ArcGIS.Geometry
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Geometry/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Geometry.dll
System.Core
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
ESRI.ArcGIS.ArcMapUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.ArcMapUI/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.ArcMapUI.dll
GpMetadataFunctions
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.4/bin/GpMetadataFunctions.DLL
ESRI.ArcGIS.Geoprocessing
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.Geoprocessing/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.Geoprocessing.dll
AHGW_GP
Assembly Version: 3.3.1.25966
Win32 Version: 3.3.1.25966
CodeBase: file:///c:/program%20files%20(x86)/Aquaveo/arc%20hydro%20groundwater%20toolkit%20for%20arcgis%2010.2/AHGW_GP.dll
ESRI.ArcGIS.DataSourcesFile
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.DataSourcesFile/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.DataSourcesFile.dll
ESRI.ArcGIS.Desktop.AddIns.Factory
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.4/bin/ESRI.ArcGIS.Desktop.AddIns.Factory.DLL
CodeBase: file:///C:/Program%20Files%20(x86)/ArcGIS/Desktop10.4/bin/ESRI.ArcGIS.Desktop.AddIns.DLL
ESRI.ArcGIS.SystemUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.SystemUI/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.SystemUI.dll
System.Xml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Configuration
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
Accessibility
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/Accessibility/v4.0_4.0.0.0__b03f5f7f11d50a3a/Accessibility.dll
WindowsBase
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/WindowsBase/v4.0_4.0.0.0__31bf3856ad364e35/WindowsBase.dll
System.Security
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Security/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Security.dll
XRayArcCatalog
Assembly Version: 10.2.0.2
Win32 Version: 10.2.0.2
CodeBase: file:///C:/Users/ruchris/AppData/Local/ESRI/Desktop10.4/AssemblyCache/%7BAB7D758E-ACB2-4583-8E74-CC9234ADA719%7D/XRayArcCatalog.dll
ESRI.ArcGIS.CatalogUI
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/ESRI.ArcGIS.CatalogUI/v4.0_10.4.0.0__8fc3cc631e44ad86/ESRI.ArcGIS.CatalogUI.dll
System.Data.SqlXml
CodeBase: file:///C:/WINDOWS/Microsoft.Net/assembly/GAC_MSIL/System.Data.SqlXml/v4.0_4.0.0.0__b77a5c561934e089/System.Data.SqlXml.dll
System.Xml.Xsl.CompiledQuery.1
Assembly Version: 0.0.0.0
Microsoft.Office.Interop.Excel
Assembly Version: 15.0.0.0
Win32 Version: 15.0.4569.1506
CodeBase: file:///C:/Users/ruchris/AppData/Local/ESRI/Desktop10.4/AssemblyCache/%7BAB7D758E-ACB2-4583-8E74-CC9234ADA719%7D/Microsoft.Office.Interop.Excel.DLL
SteveGrise
Hi Chris, is Excel installed on the machine, if so which version?
Was it working with a previous ArcGIS version install?
ChrisRumig
Hi Steve,
Yes I do have Excel.  It's Office 2010 Version 14.0.7173.5000 (32 bit) and it worked with ArcGIS 10.3.1
SteveGrise
Can you try uninstalling then re-installing the addin? Apparently there are some issues with addins when upgrading to 10.4.x from 10.3. You will need to manually uninstall then re-add it.
ChrisRumig
Tried that, unfortunately same results.
KoryKramer
Esri Community Moderator
Hi Chris, the system requirements for the X-Ray add-in indicate that Microsoft Office 2013 is required.  I would think that should be the first step in addressing the error message you're seeing.
http://www.arcgis.com/home/item.html?id=9ea218ff575f4a5195e01a2cae03a0ae
BruceLang
Sorry for cutting in, but where can I download X-Ray for Geodatabases?  My X-Ray version is 10.2.0.2, June 9, 2014 and I'm running ArcGIS 10.3.1.  Thank you.
SteveGrise
Here's a link to the latest:
BruceLang
Got it!  Thank you.
LeoLadefian5
I'm having the same issue 10.4.1
