Would like to compare approach for fire run book. I am creating an index grid for a very large rural county with some populated areas. The grid size is either too large to see details of the towns or too small and creates 4000 plus pages of the forest. I have chosen to use cartographic partitions. The only way I have found to number the pages is manually and when I calculate adjacent fields there are two pages to the east/west. If any other counties that have had similar issues would please respond with their particular approach . and or a way to automatically number cartographic partitions and calculate multiple pages in one direction that would be much appreciated. Thanks
I've moved your post into the Local space.
You will get a much better answer here as the GeoNet Help is intended for community
help and feedback. I have also added in a few additional tags. You can see more
on the community structure, and what topics are under each space from the following documents:
ArcGIS Discussion Forums Migration Strategy
Thanks!
Don
