Where Are Configuration Files for Attribute Assistant and Infrastructure Desktop?
1757
09-10-2012 12:31 PM
AlanToms
Hello All,
I have downloaded the Infrastructure Network Editing (ArcGIS 10.1) template and have installed the Attribute Assistant add-in and the Infrastructure Desktop add-in.  The documentation states the configure for Attribute Assistant should be at C:\Program Files\ArcGIS Templates\Attribute Assistant, there is no reference for the configuration location for the Infrastructure Desktop.
I have looked and been unable to locate the configuration files.  Does anyone know where the configuration really is?
Thank you
Alan
ArcGISTeamLocalGov
One a WIN7 machine, you should be able to find the configuration file here:
C:\Users\<username>\AppData\Roaming\ArcGIS4LocalGovernment\ConfigFiles
ArcGISTeamLocalGov
MikeMillerGIS
Esri Frequent Contributor
If you install the Infrastructure Desktop Tools, the last tool on the Infrastructure Reporting Toolbar will open the config file for you.
