Select Template Prompt from Infrastructure Desktop Not Working
834
09-11-2012 01:04 PM
AlanToms
I am having an issue with the Select Template prompt with the Add a Lateral and Add a Lateral Prompt tool in the Infrastructure Desktop add-in; it does not seem to be searching.  I�??ve used the same search criteria as the Create Feature template search and I get no results.  I�??ve tried the template Name and the Description and neither returns a result.  When I click OK or Cancel at the prompt it proceeds with the template referenced in the configuration file.
Does anyone have suggestions?
Thank you
Alan
MikeMillerGIS
Esri Frequent Contributor
Alan,
   Can you send me a screen shot of the issue [email protected].
