Road condition assessment questions
1303
12-18-2022 09:00 AM
Bud
Honored Contributor
The municipality I work for is in the process of revamping our road condition assessment program, practices, and data.
We currently inspect roads in-house using a legacy rating system (structural adequacy, surface condition, & drainage), but we're considering moving to a more modern rating system like PCI, IRI, etc. We're also considering moving to an outsourced inspection model in an effort to improve the quality of our road condition data.
Questions for anyone who can provide insight:
  1. What road condition rating system do you use?
    • Roads Needs (Ontario Inventory Manual for Municipal Roads)
    • Pavement Condition Index (PCI)
    • International Roughness Index (IRI)
    • Other?
  2. What are the pros and cons of the rating system you use? Would you recommend it as an effective rating system?
  3. Who performs the road inspections?
    • In-house staff?
    • Outsourced?
  4. How are the inspections performed?
    • Visual inspection? Manually record information on paper or digitally?
    • Or automated sensors in a specialized inspection vehicle?
  5. If the inspections are outsourced, what is the nature of the contract?
    • Frequency and time of year
    • Length of contract (1yr, 3yrs, etc.)
    • Any other details you can provide?
  6. What kinds of metrics do you evaluate?
    • Structure, surface, roughness, or drainage?
  7. Are there any lessons learned regarding your road condition assessment practices that you can share?
Thanks.
Omar_A
by Esri Contributor
Try to answer some of your questions.
The road condition rating system choice will depend on the transportation agency or organization's specific needs and objectives. Some factors to consider when selecting a rating system include the types of assets being managed, the data available for analysis, and the level of detail required for decision-making.
a. Pavement Condition Index (PCI): A widely used rating system that measures the condition of pavement surfaces based on distresses such as cracking, potholes, and rutting. It is a numerical index that ranges from 0 to 100, with higher values indicating better pavement condition.
b. International Roughness Index (IRI): A measure of pavement surface roughness calculated based on the longitudinal profile of the pavement. IRI is expressed in meters per kilometre units and provides a ride quality measure.
c. Roads Needs (Ontario Inventory Manual for Municipal Roads): A comprehensive rating system considering various factors, including pavement condition, traffic volume, road geometry, and safety. The system generates a rating score that reflects the overall condition of the road network.
Other road condition rating systems are in use, such as the HDM-4 (Highway Development and Management) system, a comprehensive road asset management tool that considers the economic, social, and environmental impacts of road maintenance and rehabilitation.
2. What are the pros and cons of your rating system? Would you recommend it as an effective rating system?
The pros of using a legacy rating system like structural adequacy, surface condition, and drainage are that it may already be familiar to in-house staff and may be customized to fit the organization's unique needs. However, the cons may include limitations in data granularity and comparability with other rating systems used by external stakeholders, such as state or federal agencies, in terms of an effective rating system. It would depend on the specific needs and priorities of the organization. If the organization values a more detailed and standardized approach to road condition assessment, then PCI or IRI may be more effective rating systems.
3. Who performs the road inspections? In your case, outsourcing may be more feasible for larger organizations.
Some potential lessons learned include the importance of regularly updating and validating the rating system used and the need to prioritize data quality and consistency across all inspections. Additionally, collaboration with external stakeholders may help ensure that road condition data is comparable and can be used for decision-making.
I hope this helps
Omar
