Matching tied candidate addresses when geocoding
4367
04-30-2018 05:24 AM
DylanCarlson1
Hello,
I am currently geocoding a table with over 12,000 rows of addresses. Is there a way to automatically match addresses with tied candidates ? I have over a thousand tied candidates and automatic matching would be very helpful. I appreciate any help that is given.
Thanks
MichaelVolz
Esteemed Contributor
After you have created the Address Locator (AL) open the AL in ArcCatalog by right-clicking and select Properties.  Then under Geocoding options you should find the setting for Match if best candidates tie and set to Yes.
MichaelVolz
DylanCarlson1
Thank you, this worked for me!
JoeBorgione
As an aside- ties are a good tool to qa/qc your matching data.  For example, if you are matching against street centerlines, and get a tie on 1234 Main St, that says that you have an overlap in in range values on at least two segments....
That should just about do it....
