Legend for Graduated Colors Symbology
7762
6
05-15-2015 09:58 AM
ShawnGazzano
What are the steps to create a legend (Low to High) like the one below for a layer symbolized with graduated colors?
SepheFox
Well, yes, it would be up to you to decide what defines low, medium, high, etc in your data set. To make similar categories to your example, you would click on the classify button, then pick quantiles in the drop down, and pick 4 classes in the second drop down. Then you could change the label field to low, etc.
SepheFox
In layout view, in the insert menu, select legend. Click through the legend wizard.
SepheFox
Let me know if you need any details about how to customize your legend to look the way you want. It's actually quite versatile.
ShawnGazzano
I have done that, and Style is not a step in the Wizard.
So, I continued to click Next and then Finish in the Legend Wizard to insert a "generic" Legend.
I then opened the Legend's properties and opened Style in the Items tab, but I did not see the style referenced above in the list.
Please provide further details of the steps to take.  Thank you.
SepheFox
The legend just reflects the layers in your map, so you have to set the style in the layer properties under symbology-->quantities
ShawnGazzano
Ok, so the Low to High labels are not calculated by ArcMap, but rather by the user performing editing in layer properties / symbology tab? Is that correct?
And the reference to quartiles and the quartiles math in my example, is that also completed manually by the user?
SepheFox
