How to plot density map in square km.
1723
12-12-2021 08:39 PM
Labels (2)
MikeO
How to plot density map in square km. I have the shapefile (shp) of the map and I have the data with location (longitude, latitude). I used density point function in the ArcGIS and I don't know how to convert the density to per square km. I changed the unit of my map from Decimal Degree to kilometers. I wanted to change the Area Unit in the Dot Density to square km but it is not possible. Kindly help.
DanPatterson
MVP Esteemed Contributor
Dot density—ArcGIS Pro | Documentation
You should project your data from lat/long to  a projected coordinate system (Use the Project tool in arctoolbox).  Equal area projections are recommended, but any comformal projection (eg UTM, etc) is better than working in decimal degrees
... sort of retired...
MikeO
I have got it working. Thank you very much. I appreciate your help.
