How can I track the number of appraisals being done each day?
996
08-06-2019 01:28 PM
SueEdmunson
I have a dashboard that shows where we are on the overall target but we need to do so many each day. I would like to be able to track the appraisals per day.
JoeBorgione
I'm 99% sure that dashboard can't deal with date filtering.  I worked on one where I added a numeric 'month' field (1-12) to show data on a monthly basis.
That should just about do it....
SueEdmunson
Thank you.
AndyShoemaker
Hi Sue,
Are you hoping to display the data as a gauge or an indicator?
Both of these can filter on a date field and can have multiple filters added. You can build something like: 'Appraisal' = "New" and 'EditDate' is within the Last 1 Day.
In the image below, I'm just using the editor tracking fields, but if you have an "Appraisal Date" field, that too would work. The exact same filter will work on an indicator, it will just look different.
Andy
Andy Shoemaker
JoeBorgione
My bad... We were trying to filter a bar chart as I recall and that's why I used a numeric month id.  An indicator seems like the way to go for this application: maybe have two or three: Year to date, Current Quarter, Daily....
