FIELD_TRIGGER value method to set a date?
1126
11-12-2012 09:23 AM
AlisonGaiser
I was wondering if it was possible to use the FIELD_TRIGGER value method and populate a date field? It appears that it is only a defined string or a number.
Here is the scenario, I have a table that keeps track of the road status. Included in this table is a date field for each status change (date road was poposed, date the commence work order was issued, etc.). I would like to use attribute assistant to automatically populate those fields when the status changes. I thought that the field_trigger value method might do it for me, but I am struggling with how to put in a date - sysdate preferably.
     Alison
LindsayThomas
Hi Alison
Maybe try TIMESTAMP?
http://resources.arcgis.com/en/help/localgovernment/10.1/index.html#/Timestamp/028s000000mw000000/
Would that support your workflow?
Cheers,
Lindsay
AlisonGaiser
Thanks Linda but this doesn't really meet my needs. I tried passing in the word TIMESTAMP into the ValueInfo field parameters, but it didn't work. I even tried to set it to see if I could do something with Date.Now.AsString, but that didn't work either. I also posted in the Water Utilities Forum and received a great response from Mike Miller. Unfortunately, not an answer but definitely a promising future.
http://forums.arcgis.com/threads/71283-FIELD_TRIGGER-to-set-a-date
   Alison
LindsayThomas
Glad to hear Mike gave you a promising answer.
Cheers,
Lindsay
