Maps and Apps Gallery: Internet Explorer 9
1011
10-30-2012 05:13 AM
MichaelParma1
Greetings,
We have an installation of the Maps and Apps Gallery for ArcGIS 10. It works great in Firefox, but won't load in IE9. Browser is running in compatibility mode. Debugging in IE returns: "TypeError: Unable to get value of the property 'link': object is null or undefined." Other LGIM applications are working fine in both Firefox and IE. Ideas?
Mike
MikeTschudi
Esri Alum
Hi Mike,
Please update to the latest version of the Maps and Apps Gallery.  Because the Gallery is a customizable front end to ArcGIS.com rather than a map displayer, it is not tied to ArcGIS Server versions, so you can switch at any time.  This version runs in IE 7, IE 8 compatibility mode, IE 8, IE 9 compatibility mode, and IE 9.
You can try this version in your browsers using our try-it.  If this version does not work in your browser, will you please open a support call about it so that we can solve the problem?
Regards,
Mike
Mike Tschudi, GISP | Web Application Programmer, ArcGIS for Local Government, Esri
