Editor Tracking Errors when trying to Enable the Information Model
3787
01-04-2013 04:56 AM
JohnFell
All,
I am in the process of enabling the Information Model on our parcel fabric. I received the following errors:
Field error:  Field: FloorDesignator has incorrect type on table GEDT.ADM.ParcelFabric_Parcels.
Field type should be small integer.
Editor tracking error:  Editor tracking: Creator field incorrect on class GEDT.ADM.ParcelFabric_Parcels
Editor tracking error:  Editor tracking: Created at field incorrect on class GEDT.ADM.ParcelFabric_Parcels
Editor tracking error:  Editor tracking: Editor field incorrect on class GEDT.ADM.ParcelFabric_Parcels
Editor tracking error:  Editor tracking: Edited at field incorrect on class GEDT.ADM.ParcelFabric_Parcels
Editor tracking error:  Editor tracking: Creator field incorrect on class GEDT.ADM.ParcelFabric_Control
Editor tracking error:  Editor tracking: Created at field incorrect on class GEDT.ADM.ParcelFabric_Control
Editor tracking error:  Editor tracking: Editor field incorrect on class GEDT.ADM.ParcelFabric_Control
Editor tracking error:  Editor tracking: Edited at field incorrect on class GEDT.ADM.ParcelFabric_Control
Editor tracking error:  Editor tracking: Creator field incorrect on class GEDT.ADM.ParcelFabric_Plans
Editor tracking error:  Editor tracking: Created at field incorrect on class GEDT.ADM.ParcelFabric_Plans
Editor tracking error:  Editor tracking: Editor field incorrect on class GEDT.ADM.ParcelFabric_Plans
Editor tracking error:  Editor tracking: Edited at field incorrect on class GEDT.ADM.ParcelFabric_Plans
Based on what I am reading here it appears that enabling the information model adds editor tracking fields. I've enabled editor tracking on the Parcel Editing feature dataset prior to enabling the information model. Is this why I am getting these errors? Is there a way to retain the information in the editor tracking fields before I disable editor tracking on the entire feature dataset? Thanks for any thoughts you might have on this.
JohnFell
All,
As an update on this issue I realized that I needed to disable editor tracking at the feature class level within the parcel fabric dataset. Parcels, plans, and control have the LGIM 10.1 editor tracking turned on during the enable information model command. I disabled geodatabase editor tracking on these feature classes and tables and re-ran the enable information model command without any trouble.
